Salta al contenuto principale
Kohler makes the gas powered engines for many different riding mowers & garden tractors both for home owners and professionals.
Craftsman LT2000 Kohler 17.5hp Motor - Trouble Idling, Power Issues
So can anyone diagnose what may be the problem with this mower? I inherited it and the previous owner reported it was very hard to start and took 10-15 minutes of cranking before it would catch. I took apart the carburetor and cleaned that real well, replaced the spark plug. It drives around ok but when at the top of a small hill started losing power and nearly stalled out. When I finally got it to start it was very loud and just my opinion sounded like what I think is a timing problem, but I apologize for the vague question I’m not sure where to start. Can someone tell me if that’s a good guess, how to fix it, and what other things I might look for if that’s not the problem?
https://www.youtube.com/watch?v=lcJW9KzR...
https://www.youtube.com/watch?v=pVGS0ike...
Update (01/24/2020)
This is my motor information
Questa è una buona domanda?
Punteggio 0
3 Commenti
Is your muffler plugged or your breather
da
If you hear a clinking or clanking noise internally that's definitely not normal and sounds like metal against metal which will at some point be fatal to the engine . Some engines won't idle or run very well if they are low on oil also . Safety feature so it doesn't get blown up .
da
The EPA has required the manufactures to pass clean air emissions in the small engine industry . They are running the engines so lean that after some break in periods they run like crap or are hard starting . Most no longer have any adjustments for the carburetor . The small hill issue very much points to that . If your dealer can’t or won’t fix it , lookup a new carburetor part number on kohlers web site . Use that part number on Ebay to find an adjustable replacement carb . The other option is use jet drills and make a larger hole in the main jet (jets ) . Not recommended as an owner operator fix .
da
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Adam Schaeffer  that sounds more like an issue with either the valvetrain or the piston (rings etc.)Craftsman used 3 different Kohler engines on this model. Kohler Command Single CV490S-27508 and CV492S-27506 as well as Kohler Courage SV490-0004 We’d need to know the exact engine used on yours. Do a compression test on your engine as well as a leakdown to see if it has valve or piston issues. I would suggest you pop the valve cover off and take a look at things on there. Check something like this manual for a better understanding Kohler CV engine servic emanual
Punteggio 2
3 Commenti:
Thank you. I downloaded a mower manual but that isn't very helpful. This service manual is far better. I'll post a photo of the motor information plate below, if that helps narrow any advice down.
da
@Adam Schaeffer thanks for the picture. It validates that we posted the right manual. It will not narrow this down. Troubleshooting things are the hardest part of the job. I am still leaning toward the top end having issues.
da
There can only be a timing issue if the key in the crankshaft keyway is broken (and I have seen this although rare) otherwise timing is fixed. The more likely problem is a ignition coil. They will also cause this problem after the mower warms up but it will continue to run normal on start-up. The coils are cheap and easy to replace. Use a business card to space the coil from the flywheel.
da
I have a 97 wheelhorse with koler 12.5 commander I just bought it sounded like a timing or valve train problem pecking a little and not running smoothly and would not idle
I still not sure what's wrong but it has something to do with the governor I just happened to be checking carb and I grabbed the governor and reved the motor heard a metal clank and it smooth out completely and idles fine and Everytime I start it now I just reach down rev motor and it runs fine till I shut it off
Punteggio 0
Possibly has water in the fuel. Especially if it's been sitting for extended periods…
Punteggio 0
Aggiungi la tua risposta
Adam Schaeffer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 17
Ultimi 30 Giorni: 56
Tutti i Tempi: 4,900
