Salta al contenuto principale
Annunciato il 9 settembre 2014, questo dispositivo rappresenta la prima incursione di Apple nel mondo dell'elettronica indossabile. I manuali di riparazione iFixit sono applicabili all'Apple Watch (acciaio) e Apple Watch Sport (alluminio).
210 Domande Visualizza tutte
Original Apple Watch fixed but adhesive isn’t holding screen
I have my Apple Watch working again. But the adhesive isn’t sticking. I followed the directions and applied heat and wrapped it in rubber bands but the screen is still coming up.
Any recommendations?
Thank you!
TC
Questa è una buona domanda?
Punteggio 1
3 Commenti:
What did you use in the repair? The force touch adhesive gasket and precut adhesive are both possible alternatives for use in the replacement / repair process. Did you use any of those? Heat is usually used to weaken/loosen adhesive not to strengthen a bond.
da
I used the force touch adhesive gasket.
da
Ok. I had not read that original ifixit screen replacement guide which I see recommended heat and rubber bands. If you followed the guide then be sure that you also made sure to meticulously remove all traces of leftover adhesive / gasket from all around the gasket and screen seating surface of the watch using a little bit of alcohol. Good luck!
da
Aggiungi un commento
1 Risposta
I had the same problem on a series 2 and found the battery had swollen and wouldn’t let the screen sit down properly. I replaced the battery and all was fine.
Punteggio 0
Aggiungi la tua risposta
The UnderTECHer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 145
