Salta al contenuto principale
Modello A1311 / Metà 2011 / Processore Core i5 da 2,5 e 2,7 GHz o Core i7 da 2,8 GHz
432 Domande Visualizza tutte
Replacment V-Sync cable for 2011 21.5” iMac, where can I find and buy?
Hi all.
I have a 2011 21.5” iMac answer it’s all set up and ready to go, except when fixing it I broke the v-Sync cable, I’ve been having trouble finding any for sale. So I’d love some help from the community to see if they know where I can buy some from?
Cheers
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@quinn218 do an online search for apple part number 922-9799 or Apple manufacturing number 593-1389-A  which is the Cable V-Sync/LCD Temp Sensor for an iMac 21.5inch Mid 2011. Readily available and not overly expensive.
Punteggio 2
3 Commenti:
@oldturkey03 - Good catch! I haven't needed to find one as I'd always had a junker or two to steal the part from.
Here's a source I found https://www.ebay.com/itm/Intel-iMac-21-5...
da
@danj @oldturkey03 So just to clarify, the V-sync cable also goes under the name "LCD Temp Sensor"? Thanks for your time.
da
@quinn218 it's a combination cable
da
Finding discreet display parts is always tough.
You’ll need to talk with one of the larger parts houses which recycle used systems. As an example in the UK TheBookYard I find them very helpful for odd requests. It may take a bit of time as they would need to strip down a bad display they get in for the part.
Otherwise you’ll need to replace the entire display assembly.
Punteggio 1
Aggiungi la tua risposta
Quinn sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 169
