What can I do to stop my vacuum from turning off every 10 seconds?
The vacuum worked fine the first few times I used it, but it now turns off every couple seconds even when the battery level says it has charge.
Questa è una buona domanda?
The battery cells have died. You need to replace the overpriced battery. It won't be covered under the warranty. :/
I think it’s the switch. Mine is having the same problem, but the batteries are fine. When I took apart and engaged the switch manually, it worked with no problems.
I replaced the batteries but it didn't help it still slowed down and stopped in about 20-30 seconds. I'll update this post if I find a fix.
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 41
Tutti i Tempi: 2,177
