Salta al contenuto principale
Lanciato a giugno 2012. Modello A1278. Processore Intel con Turbo Boost. Fino a 512 MB di RAM Video DDR5
1624 Domande Visualizza tutte
Display screen with "Red static colored"
I started to see “red static” on the borders and anywhere there's black on the screen. Doesn't show up on the Mac OS X boot screen. Pretty sure it's a hardware issue and not software since it goes away when I close the lid about 3/4 of the way down, but the problem is getting worse every day. I suspect that is the ribbon cable that connects my display to the logic board , any suggestion about how to replace it are welcome!
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Try starting up in Safe Mode by holding down the Shift key on start up. This will confirm if you have a hardware or software issue if the symptom disappears.
If it’s gone, install a good “Paid For” antivirus like Symantec and run it.
Punteggio 3
2 Commenti:
Hello,
Thanks for your reply. I test it on Safe Mode and the problem continue. So is Hardware :(
Regards!
da
Ok, now lets see if we can narrow it down. Hook up an external display and see it it appears on the external. If so, you have a GPU issue, if not then we go to the display.
da
A red screen is apple’s version of the blue screen of death.
Punteggio -1
1 Commento:
So, Purple is Goggles screen of death ?
Red is just a color it's not a sign of a OS failure its a sign of a video signal getting messed up.
da
Aggiungi la tua risposta
Frankhil Contreras sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 14
Tutti i Tempi: 5,561
