Salta al contenuto principale
Il decimo telefono di Samsung della serie top Galaxy S, lanciato a marzo 2019. Dotato di Android 9.0 (Pie).
71 Domande Visualizza tutte
Is it possible to replace the charging port on my galaxy S10?
My charging port is faulty and I have a lot of experience with iPhone repairs and decent experience with galaxy repairs. I looked at your teardown of the S10. Since the charging port is soldered onto the motherboard, would I need amazing soldering skills to replace it?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes, it is possible, the microphone is really close, cover it when you are applying heat. You can't see the pins when you are removing and installing the new port, so you need to do a clean job and all pads needs to have the same amount of tin.
Punteggio 1
Aggiungi la tua risposta
Jak Esposito sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 27
Tutti i Tempi: 656
