Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
Is this a faulty battery?
Hey guys, I recently replaced my Macbook pro 13” early 2015 battery and wanted to ask if this looks like signs of a faulty battery.
Upon installation I fully drained and recharged the battery and capacity showed to be 99%. After a few days (around 5 or 6 cycles), the battery capacity dropped from 99% to 94.6% mid-use while the computer was pretty warm.
On the next charge, my Macbook randomly shut off on its own mid-use again while at 70% charge. Turned it back on and kept using it, no noticeable difference in performance or battery life and didn’t shut off again since then. Now Im going on 9 cycles and according to Coconutbattery and Macbook finder the battery condition is “normal” and still at 94.6% capacity (so far). Manufacturer shows as SMP.
The battery performance itself looks to be fine and I’m getting a decent charge out of it (at least seemingly better than before), however when running apple diagnostics I’m getting the message PPT004 battery needs service. Should I be looking to replace it again? I’m also still on OSX 10.10
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Risposta Più Utile
Yes, it sounds very much like a battery issue. I am guessing it is not a Genuine Apple battery.
Try to drain it completely before charging it up again to full, but I suspect only an original battery will take that error away in diagnostics.
Punteggio 1
Return the battery as its defective!
Punteggio 1
Aggiungi la tua risposta
Gent Zalli sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 171
