Salta al contenuto principale
Il tablet Surface Pro di quarta generazione, lanciato sul mercato il 26 ottobre 2015.
208 Domande Visualizza tutte
How can I replace top glass of layer only (LCD and digitizer are fine)
I cracked the topmost glass layer of my Surface Pro 4’s screen. The LCD and digitizer are undamaged and working perfectly. How can I just replace that top glass layer? I found $15 screen protectors made of glass, which I can use to replace the cracked layer. But I'm not sure how to peel the cracked layer off.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
If you are fixing one glass only it is not worth. You need a hot plate and metal wire to remove the front glass, and optical clear adhesive to put a new glass on it.
The "Glass" needs to have the digitizer (touch screen) atached it, a tempered glass or screen protector wont work.
You need tools, screens for practice and hours of work.
Punteggio 2
Aggiungi la tua risposta
Sam D sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 602
