Salta al contenuto principale
Model A1001 or A1025 / 667, 800, 867, or 1.0 GHz G4 processor
Why cant I get the screen to power on?
it used to come on the screen but now nothing and the comp boots
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hook it up to an external monitor to try to isolate the problem. Hold a flashlight at an angle to the screen and see if you can discern the desktop. Move the screen up and down and see if any changes take place. Let us know your results and we can go from there.
Punteggio 3
Over time, display cables can rub aginst the case and they stop working
Check if the connectors need to be reseated, if they do, reseat them
If they are secure, the LVDS cable may be bad, replace it and report back
If this dosen't help, I would imagine the GPU has come loose, remember, this computer is from 2001, so that could be possible
Punteggio 0
1 Commento:
Nick, take a break. The GPU is soldered in. This answer, while informative, really doesn't help diagnose the problem. Sorry.
da
Aggiungi la tua risposta
charlie sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 584
