Salta al contenuto principale
L'aggiornamento di Marzo 2015 della linea 13" dei Macbook Pro con Retina Display (modello A1502) adotta processori Intel Core i5 ed i7 di quinta generazione, introduce inoltre il trackpad Force Touch.
1185 Domande Visualizza tutte
Used a metal to unlock display cable, sparked and Mac restarted. Dead.
I suddenly got a red vertical line in the display and then I opened the Mac, undid the display cable with a metal tool, there was a small spark ⚡️ and then my AirPods disconnected, I opened the Mac and see it has been restarted (with colorful images) and then I enter into the Mac, everything gray, normal windows where there, like logos are colorful but no desktop picture and all plus windows were Weird sized..! I restarted but it wasn’t restarting so I long press the power button.
Tried turning in, but no luck, opened, disconnected the battery and reconnected, fan works sometimes and the trackpad clicks.
when connected to the MagSafe it’s orange
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
For as much as I can sympathize for your loss it’s quite clear you don’t have the skills to fix the fault or you wouldn’t have caused it in the first place by using metal tools on a running board which is about the best one can do to cause extensive damage. Taking your Mac to a shop/lab into component level repairs would be the best you can do to get it fixed, or contact Apple if you prefer.
Punteggio 2
Aggiungi la tua risposta
StanlyYa sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 5
Tutti i Tempi: 67
