Salta al contenuto principale
La versione allargata del decimo telefono di Samsung della sua serie top S, presentato nel febbraio 2019. Dotato di Android 9.0 (Pie).
107 Domande Visualizza tutte
Is Samsung Galaxy S10+ waterproof?
I am looking for the Samsung phone which should be waterproof. i want to confirm this is Galaxy S10 Plus is a waterproof phone?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
2 Risposte
Soluzione Prescelta
IP68 dust/water resistant (up to 1.5m for 30 mins)
You can read here what means IP68
https://en.wikipedia.org/wiki/IP_Code
Dust-tight
Immersion, 1 meter (3 ft 3 in) or more depth
according to:
https://www.gsmarena.com/samsung_galaxy_...
Punteggio 5
Hi,
No phones are truly water proof.
Water proofing gets weaker over time, so if your phone is 2nd hand or refurb, then the water proof ratings should be taken with a grain of salt.
That being said, it will give you a good idea if your phone will survive a accidental water exposer. If water does get in a phone that had high water resistance rating, odds are that the damage would be limited if any.
I don’t reccomend ever putting a phone in water on purpose. Water may find a way in. We often see water damage device with hight ip rating at the shop because the customer thought it was water proof.
I hope this helps
Punteggio 1
Aggiungi la tua risposta
Shifa Aman sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,447
