Salta al contenuto principale
The 2018 version of the Samsung Galaxy A7 smartphone released in October 2018.
51 Domande Visualizza tutte
My screen is black but all noises in background
My phone screen is black but if is still working except from this. I have tried all the recommended options on pressing volume and power buttons but nothing is working. I can even answer a call if a touch the screen at the correct bit when it is ringing.
Questa è una buona domanda?
Punteggio 4
1 Commento
I have the exact problem right now. How did you fix it? Did it cost you too much? I'm afraid to do it on my own, so I'll go to the phone center. But not sure if it will cost quite an amount of money
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
Andrew Taylor  sounds like a display issue. Replace the display assembly (digitizer may still be working but display may have failed) and re-evaluate. This video should help you with your phone repair.
Or you can check your circuit board
All components are around HDC7004
Punteggio 2
Aggiungi la tua risposta
Andrew Taylor sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 8
Tutti i Tempi: 949
