Salta al contenuto principale
An Android-based Samsung tablet serviced by the Verizon Network that was released in September 2015
Samsung tab S2 lcd replacement
can I used another lcd screen from a S2 to replace one that has lines on it?
Questa è una buona domanda?
Punteggio 0
1 Commento
use a lcd screen from one TAB S2 to replace a burnt screen on another Tab S2 - is it possible?
da
Aggiungi un commento
1 Risposta
Risposta Più Utile
@dhn yes, you can replace the LCD’s from one S2 to another S2
Punteggio 1
2 Commenti:
Thank you for your quick response. Are you 100% sure ? Just asking because a local shop here said no and they charge $275. I can easily find a good use one way less than that
da
Yes you can use one from an S2 to "transplant" to another S2. They are not really easy to remove but are identical for all S2. Usual replacement is with the frame and cost for a replacement is around $150-$200 USD. To replace it follow something like this video https://www.youtube.com/watch?v=MSG67j-J...
da
Aggiungi la tua risposta
Don sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 12
Tutti i Tempi: 170
