Hi,
With an iPhone 4S, I had the WiFi problem for no apparent reason, but otherwise don’t really know about that. I will have a look and try to get back to you on that.
Home button wise, it could easily have been damaged whilst moving across t the new screen. I’m the iPhone 7 and above, if the home button is damaged, not only will you lose Touch ID forever, but you will also lose all home button functionality. The flex cables are extremely delicate and easy to break. Use a microscope to see if you can spot any damage. Was there anything that was left behind in the old screen, causing it to function in the old screen but not in the new?
Mayne take it I to a reputable repair shop and ask for their advice, as it is hard to know without seeing it.
(I have heard of a replacement home button, which uses Bluetooth. As the Apple repairs can be pricy, I reccommend looking it up. I found it from YouTube, I will leave the link to the video in the comments of this answer)
Votato
Annulla
Punteggio
Annulla
Scorri questo thread per trovare il posto appropriato per questo commento. Quindi, fai clic su "Allega commento a questo post" per spostarlo.
