Salta al contenuto principale
A1706/ EMC 3071 — Lanciato nel novembre 2016, questo MacBook Pro introduce la Touch Bar OLED. Ha CPU Intel Core i5 dual-core "Skylake"e 4 porte Thunderbolt.
239 Domande Visualizza tutte
Will not power up
This one was working fine. It was shut down and in the morning I got nothing.
I disconnect the mag-safe adapter, disconnect the battery from the logic board. Press and hold the power button for 10 seconds. Now plug the battery back in then the mag-safe and did not get a spontaneous reboot. The keyboard lights occasionally, but no post tone. It will shut down the keyboard lights when I press the the location of the normal start. The fans do not come on. @danj any ideas? This machine has not been worked on by anyone else, I did the initial system installation and data migration in late 2016. It has had no problems till now. I’m pretty sure it would also have Symantec anti-virus on it. I left it plugged in overnight, so I assume the battery is charged.
Questa è una buona domanda?
Punteggio 1
7 Commenti
@mayer - MagSafe?? This series uses a USB-C power adapter.
da
@danj of course it uses a USB-C. But it's not a mag-safe or I could see if it was charging, but I can't. Thanks for improvement Apple.
da
@mayer - Just making sure we're betting on the right horse here ;-}
When you open the lid do you see the battery icon when you have the power adapter plugged in?
You may want to get a USB-C power meter as I find the display fails to show up when I would have expected it to. Satechi USB-C Power Meter Tester. I wish Apple had given us a simple charging LED.
da
@danj I see nothing when I open it. It was only when I did the battery disconnect and reconnect that the keyboard lite up. Yes, I bought a power meter tester several months ago when you recommended one. I will give it a shot in the morning.
da
@mayer - Any news?
da
Mostra altri 2 commenti
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Sent into Apple. A tier 2 repair.
Flat Rate 2 Repair Charge MB/MBAIR/MBP13 $405.94
Labor Charge, IB/MB/MBAIR $108.25
PORTABLE SHIPPING CHG $21.60
Total in USD $535.79
Plus tax
UPDATE 1/16/20
Apple ending up replacing the logic board, and the display and the bottom case.
So just in parts costs, the Flat Rate Repair was really worth it.
Punteggio 2
3 Commenti:
@mayer - Happy you got it fixed! Hopefully you didn't spend too much on the system to start with.
da
@danj just sent it in yesterday, it is a customers machine.
da
Kevin If they quote you a Flat Rate Fee, that's it, no charge for any parts.
da
Aggiungi la tua risposta
mayer sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 3
Tutti i Tempi: 446
