Salta al contenuto principale
Repair guides and support information for RCA-brand tablets.
put it in charge and it never turned back
I have a RCA computer. It's the kind that has a reconnectable keyboard and I have only have it for a year all of the sudden I put it in charge and it never turned back on I have kept it in a charger for 3 days and still not working it's doesn't have any volume up buttons on the tablet itself but it only has it in the key board and I can't get it to work. Does anybody know what else to do?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Risposta Più Utile
Emma's Art  try to find a complete model number somewhere on your tablet. Right now you need to start systematically. Check your AC adapter first. Make sure that it is working. You may need to check the output with a multimeter. If that AC adapter is okay you will need to check the DC in jack of your tablet. Make sure that it is in good working order and has nothing obstructing it, bend pins or corrosion (lint, dirt etc.) blow it out with a few puffs of “canned air” After that you may have to consider opening you tablet and replacing the battery as wella s checking the jack to make sure it gets power when plugged in etc. We can try to further assist you but we definitely need a t least a model number.
Punteggio 3
Aggiungi la tua risposta
Emma's Art sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 45
