Salta al contenuto principale
Rilasciato a Gennaio 2015, l'XPS 13 ambisce ad essere il rivale commerciale del MacBookAir, con lo schermo senza bordi e il Touch-screen opzionale.
75 Domande Visualizza tutte
Four flashes. Battery isn’t recognized by laptop.
Just replaced my dying battery with one from ifixit.
The white charging light appears when I attach the ac adapter, then I get four orange flashes.
The internet says this means a bad battery. Did I receive a bad battery or is there something else that could be at play here?
EPILOGUE: I followed the recommendation, started the process. For giggles, I unplugged and repeated the connection and realized it had been user error. Fixit troubleshooting 101.
Questa è una buona domanda?
Punteggio 1
1 Commento
Hi,
What happens if you leave it on charge for a while, does it stop flashing?
Have you tried re-installing the old battery to check if the problem is still there, assuming that it didn't do this before?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
EPILOGUE: I followed the recommendation of jayeff and started the process of confirming connectivity with the old battery. For giggles, I unplugged and repeated the connection and realized it had been user error. I just hadn’t pushed the connector in far enough. Shame on me. Fixit troubleshooting 101.
Punteggio 0
1 Commento:
I am having the same problem you've described, but with no luck on playing with the connection. The old battery re-connected just fine, but the ifixit battery didn't. After hours of sitting plugged in, the flashing orange light continues, and when I unplug the computer it immediately dies. So the battery isn't connecting. Makes me wonder if i got a bad battery.
da
Risposta Più Utile
discosammy enter the "Epilogue" as an answer so we can mark this question as resolved.
Punteggio 1
Aggiungi la tua risposta
discosammy sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,008
