Salta al contenuto principale
Un discendente dello smartphone LG V10, simile all'LG G5, rilasciato il 29 settembre 2016. L'LG V20 si distingue per i numeri modello F800, H910, H918, H990 DS Dual, H990N Dual, H990 T, LS 997, US 996 e VS995. È disponibile con finitura titanio, rosa o argento con 32 o 64 GB di memoria interna.
51 Domande Visualizza tutte
How to fix or replace copper battery connector prongs
How do i fix or where can i get a replacement battery connector for a LG V20 H990ds. One of the four copper prongs that touches the battery's contacts is broken. LG is evasive about this part and does not offer a solution. Thank you.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You can buy a motherboard for parts, and you can use another LG model like LG Aristo, they have the same connection.
Punteggio 0
2 Commenti:
Thanks Fernando. LG technitions wont do that and the independents I've shown the phone to are afraid of damaging the motherboard from the heat of soldering. Do you think that is a valid fear? It seems improbable one of LG's better phones can be rendered useless by a simple part like this but it's starting to look that way. The worst of it is LG says my model is an "international" phone so I have to take it to Taiwan for repairs. I live in Chile.
da
LG Motherboards are thin, to much heat can damage chips on it, can be done, but you need somebody with experience to finish the job,
if I were in your shoes , i would solder a small cable directly to the battery.
da
Aggiungi la tua risposta
yapo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 486
