Salta al contenuto principale
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
custom pc not turning on/displaying
It turns on, but doesnt display, leds are red, shuts off after a little bit then turns back on. IDK. No other site answered my questions, I already replaced power supply.
Questa è una buona domanda?
Punteggio 0
1 Commento:
Hi Karsten Espolt
Sorry to hear about that,
Please list out your PC components as much as possible, e.g.
Mainboard, processor, RAM, GPU, Power Supply make, etc.
What had you done btw?
da
Aggiungi un commento
1 Risposta
Seems like the PC is failing to POST successfully. From the issues you’re having specifically I’m thinking it’s a CPU problem:
  • Check to make sure all power connections are made correctly and securely including the CPU power connector.
  • Check to make sure the CPU is installed corrected and securely into the slot and that the motherboard wasn’t damaged during the installation of the CPU cooler.
It’s worth cross checking your parts to make sure they are all compatible with each other. If you are able to list them here we can help check that as well.
Punteggio 0
Aggiungi la tua risposta
Karsten Espolt sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 75
