Salta al contenuto principale
Lanciato il 4 novembre 2017. Modello A1865, A1901. Disponibile con GSM o CDMA / 64 o 256 GB / Colore Silver o Space Grey. Si pronuncia "iPhone 10".
Error 4013 bootloop on iPhone X
Hello!
Today I am getting the apple boot loop it is asking me to connect to iTunes.
From previous, I already had a crack on the left bottom corner of the screen.
Today when I noticed this problem, my phone was kept in the rest room close to water but I am not sure if water entered or not.
I took it to the apple store and they said it is because of 4013 error and asking to restore.
Before doing that, I wanted to get my stored data first because I am not sure whether I will be able to get my data back or not during this process.
So, please, does someone know a REAL solution to this problem or any shop where I can take to fix it?
My priority is to get my data back.
Thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Risposta Più Utile
If the Apple logo during the start keeps coming off and on constantly, the short answer is, you probably cannot do anything about it, because it is likely the mainboard issue. You are stuck with a motherboard replacement cost of about $750 CAD (I'm Canadian) as Apple doesn't take ownership when its devices fail after the warranty period.
I had had an issue with my MacBook Pro 2015 too, the anti-glare coat was pretty much melted on the monitor due to a manufacturing error. When I took my MacBook, I was told that they cannot do anything, because I didn't bring it during the recall for a free replacement. I had listened to the same song by then, the song's name is: It's Apple's Company Policy for its lemon products. I later learned that it was called "Staingate".
It's so disappointing that Apple doesn't take ownership of its poor-quality electronics and there is no credibility. Wishing all the best of luck to all current and future Apple users, as you folks have a very frustrating and expensive route ahead.
Punteggio 1
1 Commento:
So basically keep up that expensive warranty insurance or don’t update your iPhone. Which is BS. Really disappointing
da
Try dail “*#06"#”.
If you can’t see your IMEI, then you got a problem with your baseband.
Punteggio 0
1 Commento:
How can i fix my iPhone X baseband problem
da
Remove charging flex and check most of that cases on iPhone X have such problem throw vibrator circuit shorting on charging flex.
Punteggio 0
iPhone X ERROR 4013 SOLUTION - REALLY BIG HINT - THE ERROR 4013 MYSTERIUM SOLVED
https://www.youtube.com/watch?v=JM-04aWO...
Punteggio 0
1 Commento:
It’s in German ?
da
Aggiungi la tua risposta
Shal S sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,600
