Salta al contenuto principale
The MSI GS63VR 7RF Stealth Pro is a gaming laptop made by the company MSI in 2017. This page includes repair guides for the GS63VR 7RF-252US-BB7770H16G1T0DX10MH. Model Number: MS-16K2.
How do I lubricate my CPU fan?
Hi guys, what's the best way to grease my GS63VR fans? They're screaming very loud and it seems to be the time to lub them. The question is, what's the best way to do it? And what oil should use?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Just replace them as there could be other problems. If you must, then peel the label up and use a fine quality sewing machine oil and a get a tiny drop of the oil on the end of a pin or tooth pick and drop it on to the top of the bearing. NOT TOO MUCH!
Remember, this is only a tempoary fix for a few days before you get the replacement fans
Punteggio 2
Most of these are sealed. Just replace it.
Punteggio 1
The fans on GS63 are not sealed, just 4 screws on the cover. I repasted the GPU and CPU, as well as cleaned the cooling radiators and fans, while at it I also lubed the fans. the temperatures under full load went down by 5-6 C.
Punteggio 1
Aggiungi la tua risposta
renofaria sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,189
