Salta al contenuto principale
The aluminum PowerBook G4 was released by Apple to replace the previous titanium-body model. The 12" and 17" versions debutted in January 2003 with the 15" version following in September of that year.
683 Domande Visualizza tutte
PowerBook will not boot past gray screen - no logo.
I reset the pram, reset the PMU, cannot boot in single user mode, do not have reinstall disk.
I have scoured the internet to find several people having the same problem, and have never come across a resolution.
I believe it is some form of corrupted system files.
Guess I will buy the OSX disk and see if that does the trick- my last viable option.
Has anyone had this problem and actually resolved it?
Thank you,
CS
Questa è una buona domanda?
Punteggio 1
1 Commento
Have you changed any of your Ram?
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Try starting up in Safe mode by holding down the Shift key. Get an original system disk from Apple for $15
Punteggio 2
http://support.apple.com/kb/ht1533
There's a link to start-up combo keys.
You could always try TechTool Pro or Disc Warrior.
I am currently resolving an issue which is quite similar and so far it is looking good. iMac G5 runs so slow when boot from disc. But when the install is done I will find out it the format and install works. I will know in about 2-3 hours.
Punteggio 1
Aggiungi la tua risposta
sdgery34f34f sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,344
