Salta al contenuto principale
Annunciato il 9 settembre 2014, questo dispositivo rappresenta la prima incursione di Apple nel mondo dell'elettronica indossabile. I manuali di riparazione iFixit sono applicabili all'Apple Watch (acciaio) e Apple Watch Sport (alluminio).
210 Domande Visualizza tutte
No display after screen and battery replacement
I recently ordered from iFixit three items to repair my apple watch. Battery (just was not holding a long enough charge), force touch sensor and used sapphire screen (screen was shattered from a three foot unlucky angle drop). After installing all three without any issues (no torn cables, took about 30 minutes), I get no display.
When I charged my watch for about 1 hour the battery gets warm (the actual battery not the whole watch). Seems about as warm as is normally the case. I have tried putting the old screen on and the old battery back in with no luck. I have tried hard resets (holding crown and side button for up to a minute) . Nothing is working and nothing looks even slightly damaged. Am I out of luck? I throughly read through iFixit instructions before starting.
This is the first gen device. Series 0 or revision 1. As a side note I have successfully repaired at least ten iPhones; screens, batteries, cameras and even a proximity sensor (very small parts). One time I even tore apart a water damaged iPhone 4, cleaned all the parts, including the logic board with isopropyl, and had it running for a year.
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Risposta Più Utile
Did you disconnect the battery when plugging in the screen? I know you can fry iPhone screens if you plug in the screen after you plug in the battery. Do you have a slave display you can check the watch with? Does the watch show up as connected to your iPhone when it gets warm?
Punteggio 1
2 Commenti:
As per the instructions on iFixit I did first disconnect the battery. I have tried the old screen (which still worked, but is badly cracked) with no luck. The iPhone 8 plus does not detect the watch at any point. Thank you for your response.
da
I have recently installed a new battery and a new screen to a 1st gen stainless steel Apple Watch, too. The watch gets warm and the screen doesn’t respond. Maybe the screen is the issue?
da
Aggiungi la tua risposta
Leon Ewell sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 689
