Salta al contenuto principale
The LG Stylo 4 is a stylus-equipped midrange slate-format Android smartphone released by LG in 2018. Identifiable by model numbers L713DL and Q710(AL, CS, MS, TS, ULM, ULS, and US).
20 Domande Visualizza tutte
Cracked Glass on phone
Only the glass is cracked. The LCD screen is perfect just can't use phone due to glass cracked and cuts finger.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
You can just get a glass only repair done so that the screen will be separated from the cracked glass and a new one would be installed. Or you can get a whole screen replacement that would replace the glass and screen. If you want to be cheap you could always put some clear tape over the glass until you get it replaced?
Punteggio 0
Aggiungi la tua risposta
Michael J Hudson sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 344
