Salta al contenuto principale
Annunciato il 9 settembre 2014, questo dispositivo rappresenta la prima incursione di Apple nel mondo dell'elettronica indossabile. I manuali di riparazione iFixit sono applicabili all'Apple Watch (acciaio) e Apple Watch Sport (alluminio).
Is there a real way to enter DFU?
I have an old apple watch that was stored for a long time, now it doesn’t turn on, it gets stuck in a beating apple logo when connected, support sais there is no solution but a paid replacement. I found on internet an iBUS cable that claims to be a way to enter DFU mode so you are able to apply a full restore from the OS image. Do you know if it is real and if it works?
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Yes, the iBus tool is what you will need to enter into DFU mode.
Punteggio 3
4 Commenti:
@danj where can we get this tool?
da
Can I purchase the iBUS tool from iFixit?
da
@bertrandth82713 - iFixit doesn’t offer this tool, here’s one source For Apple Watch Restore Cable IBUS S1 S2 S3 S4 S5 38mm 42mm Recovery WatchOS
da
I have an original Apple Watch with a corrupted iOS and I bought an iBus S1 to attempt a recovery. Unfortunately signed OS update files are no longer available, so as far as I can tell an update with iTunes is no longer possible.
The only alternative I've seen is to get a membership on the manufacturer's site, which then allows you to use their tools to update with (presumably) an unsigned file.
I bought mine used without a serial number so I can't register it, leaving me unable to use their tools and therefore unable to update my watch. It does, however, work great with iTunes if I only had a valid file to use.
da
Aggiungi la tua risposta
raiman264 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 37
Tutti i Tempi: 658
