Salta al contenuto principale
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530 Domande Visualizza tutte
Wiped Apps by mistake
hi. I accidentally deleted all the applications from the computer, then i must have emptied the trash, so i can not open any applications, the applications icon still show , but once I attempt opening them a question mark appears on the application icon, however, preview still works which means i can see the pictures on my lap top from afar, i can also listen to music via preview, i am stuck too , I do not know what to do.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
If you still have somewhere your original install CDs it would be quite simple to restore the Apps in your Mac, if I remember right the iBooks came with their separate Applications CD.
Punteggio 3
Perhaps you have lost essential files? Are you searching for Mac iBook G4 recover to gain entry of all unavailable data? If you do then you have to know that it is probable to do so and obtain backdropped files in the original structure.   Even though Mac iBook G4 a good advance gadget designed by Apple company Inc, however, it is also not really beyond the particular mishap. Given that this device offers several services hence presently there can different kinds stored onto it and once this gets impacted and becomes unavailable then it actually hurts. This really is just like information loss circumstance in which you happen to be bound to consider Mac iBook G4 bring back to recover unavailable files. Occasionally due to unforeseen power to reduce or generate failure consumer can not gain access to their document. In addition because of OS problems you may also unable to get needed data. Such conditions it is very important to perform Mac pc iBook G4 restore to obtain back damaged or removed files. To be able to complete this one can make use of CD/DVD or even USB generate to totally reset the device however it may drop previously saved data. You are able to avoid this particular possibility plus restore Mac pc iBook G4 data at the desired area by using the greatest third party device. Therefore it is recommended to choose the best solution to complete Mac iBook G4 recover in the imply time.
Regards,
Lewis
Punteggio 1
Aggiungi la tua risposta
clementine tariro mapfumo sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 5
Tutti i Tempi: 59
