Salta al contenuto principale
Lanciato nel giugno 2009 / processore Core 2 Duo da 2,53 GHz
170 Domande Visualizza tutte
White band on screen with pink lines
Hello everyone,
I have an (old) Macbook Pro, and for quite some time now, I have a white band on the screen with some pink lines. The screen also is quite loose, but I don’t know if it’s related to the problem. Sometimes the band goes away, but I would say that on average it is always there.
I have attached the picture for you, for some more context.
I have also an LVDS cable for the replacement, but I don’t know if it’s necessary, because I saw that replacing it is a tough job. I am also waiting for a second display to arrive, but I think the problem is related to the cable.
Do you think I can solve this by replacing the LVDS cable? Or I might better check the one I have, and see if there’s something wrong with the connection on the motherboard?
Thank you so much for helping me.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Hook it up to an external monitor to verify if this is a display issue (which it appears to be), or a GPU issue, m then you will have a better idea of how to proceed.
Punteggio 2
2 Commenti:
Hey @mayer I have just attached a second display.
I don't see any white band over there. So "gladly" :) is a display issue.
Now I have to think about just replacing the cable, or the entire lcd.
What you would do?
da
You have a LCD issue, time to replace the display.
da
It looks like your LCD is damaged you can get this replaced by using the guide below. I hope this helps! Taza
MacBook Pro 15" Unibody Mid 2009 LCD Replacement
Punteggio 2
Aggiungi la tua risposta
Luca S. sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 84
