My tv do not on, only have red light blink 6 times and yelow light 1?
the red light blink 6 times and yellow 1 time it has repair.?
Questa è una buona domanda?
Exequiel Martinez double check the code. To get the error code, after the tv tries to turn on and fails (blinking red led), go up to the front panel press and hold ACTIVITY + CH DWN until the led starts blinking in a repeating pattern. let us know what you get. What you originally have is a code 61 which is a No Lamp Enable which is received at the DM and Ballast. So this could be an issue with either the fans, the color wheel or the lamp. Let us know if the fans spin, and if the color wheel spins.
Here is the service manual that should help you repairing your TV Mitsubishi WD60737
I think it's the color wheel, because the color is not clear.
OK I dud what you said but all I get is 6 blinking red and 1 orange lights
Should I try using the bulb I have an extra one here
@charlesehawkins might as well since you have a spare readily available
Ultime 24 ore: 0
Ultimi 7 giorni: 16
Ultimi 30 giorni: 63
Tutti i Tempi: 4,930
7 Commenti
I have a mitsubishi 76” color television set WD - 73C12 that blink 6 red and 1 yellow blink. Is my television repairable and will it be expensive to repair?
da Kenneth Keeylen
The exact same thing just happened on my Mitsubishi projection TV. Mine is 12 years old, model WD-73738. This is the third bulb to burn out. Front light is blinking 6 red and 1 amber.
da Paul Devery
Mine is a- WD-82C12 82 inch DLP TV Mitsubishi it’s 6 red blinking lights and one yellow blinking light
da Teresa Lynn Poore Carver
@teresalynn51796 for your model it's the same thing. That particular error code tells us that the lamp isn't energizing and possible failures are either that the lamp isn't installed correctly or that the color wheel in the light engine isn't spinning (broken or jammed) or that the light engine circuitry has failed. Does that help you enough? If not then we convert this into its own question and get more into the details.
da oldturkey03
My Mitsubishi WD-82738 82in blinked 6 times red and 1 orange what does this mean
da katherine c pratt
Mostra 2 altri commenti
