Salta al contenuto principale
The Asus X555L is a low budget laptop that came out in May of 2015. The model depicted in these guides is X555LA-SI305041, an Intel Core i3 laptop designed to be affordable for consumers. Similar model numbers: X555LB, X555LD, X555LF, X555LI, X555LJ, X555LN, and X555LP
60 Domande Visualizza tutte
Charging port broken, how to replace it?
In short, title
a few months ago the charger on my Asus x555L started acting strangely, only charging when it was turned at a certain angle. now it refuses to charge entirely, and the charger will not stay secure in the port as the port is broken. how would I replace the port with a new one, thereby fixing the issue?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
Risposta Più Utile
The charger port is soldered onto the board meaning you’d need either a hot air rework station + soldering station to remove the port or a soldering iron station + solder sucker to remove the old solder to remove the old charger port.
A lot of the time these ports can actually be repaired without replacing by redoing the solder on these ports as seen in this video:
https://www.youtube.com/watch?v=qWXISqQh...
Punteggio 4
Aggiungi la tua risposta
stan_albatross sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,097
