Salta al contenuto principale
Informazioni sulla riparazione e la soluzione problemi per l'HP Pavilion 15-au. Si tratta di un computer portatile da 15 pollici prodotto da HP come parte della linea Pavilion.
Why does my laptop power light flash 3 times but not turn on?
I have a hp pavilion notebook 15-au181na laptop. When I push the power button the light by the place where you plug in the laptop charger flashes 3 times but does not turn on.
It all started when I was trying to reinstall windows 10 using a USB. This is because I had to replace my laptop bottom case and keyboard because the old ones were cracked and I had to remove the mother board, battery and hard drive and then put them back in. When I did this then the computer would not boot up and therefore I had to reinstall windows 10 using Rufus and a USB.
I have tried removing the battery and then pushing the power bottom for 30 seconds however, it has not worked. I also tried plugging in the power without the battery and this also has not worked.
Does anyone know why my laptop will not turn on?
Thank you if you can help.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
I had this recently on another HP and it turned out to be a faulty hard drive. According to the HP website that is faulty hardware and the laptop should be returned to a HP service center.
Punteggio 0
Aggiungi la tua risposta
A019 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 21
Tutti i Tempi: 1,697
