Salta al contenuto principale
Introdotto il 19 settembre 2014, questo iPhone con schermo da 4,7" è la versione più piccola dell'iPhone 6 Plus. Identificato dai numeri modello A1549, A1586, and A1589.
4994 Domande Visualizza tutte
Can I swap speakers between two iPhone 6 devices?
Hi. My parents own iPhone 6 - a 16gb and 32gb versions. My dad’s iPhone is a 16gb but he has been facing issues with the touch screen. My mum’s iPhone is a 32gb and off late she has been complaining of not being able to listen to conversations and has to switch on speaker mode to speak. I’m upgrading her to a XR. Is is possible to swap the speakers or mics from the 16gb to the 32gb? If possible, my dad can start using the 32gb and dump the 16gb with touch issues. Kindly let me know or point me to answers in the forum. Appreciate your help. Thank you.
Questa è una buona domanda?
Punteggio 0
1 Commento
Thanks for the replies.. will try your suggestion on cleaning the speaker filter and the mic..
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
Let's say if you are making the call and it's very hard to hear the person you've called it is usually just a very blocked earpiece speaker filter.
Use a soft bristle brush to clean the black speaker filter at the top of the screen quite a few times and it should be loud again.
If the other person can barely hear you try cleaning the little hole right next to the headphone jack as that is there the microphone is.
Punteggio 2
Storage size doesn’t matter in iPhones, is it is iPhone 6 any part inside will fit in another iPhone 6.
Punteggio 1
1 Commento:
Now just to be clear iPhone 6 is not equal to (iPhone 6+, iPhone 6S, iPhone 6S+)
da
Aggiungi la tua risposta
Kaya Natarajan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 66
