Salta al contenuto principale
Repair guides and disassembly information for Asus Republic of Gamers laptops.
Stuck on "please wait" when trying to wipe Asus ROG laptop
First off, I believe I have the Asus ROG model: GL502v, according to the bottom of my computer. My computer has too many viruses and is much slower than it was even a year ago, so I decided to wipe it. I went to Recovery settings to delete all files and wipe computer. It said something like ‘this should only take a few minutes before you’re computer restarts’. So it got to 100% and initiated the restart. After ten seconds the ROG logo came up and it said ‘please wait’. *Idk if there is normally a loading '‘…” after it but mine didn’t have one*. I’ve tried doing this on multiple occasions and it always gets stuck on this screen. *Yes I have tried waiting over night*. Is there a way to fix this or wipe my computer in some different way where this may not be an issue? I have tried the multiple different options it gives me when doing it the generic way through Settings>Update & Security>Recovery>Reset this PC, but the same thing happens. The only way to fix it is by holding down the power button until it turns all the way off then turning it back on only to get the message: “something went wrong when restoring your pc. no changes were made”. Please Help
Questa è una buona domanda?
Punteggio 0
1 Commento:
I'm having the same issue, but the whole reason I wanted to wipe it was everything started breaking down. First thing i noticed was the mic stopped working cuz wdma_usb.inf wasn't installed and couldn't find updates,etc. Next thing my troubleshoot "didn't have an app or service to run" something like that, next I can't open my game because now gaming service won't run. I'm tech retarded as it is, and i just got this laptop. Is there some way to fix this without a reset?
da
Aggiungi un commento
2 Risposte
I have had that problem on a number of machines that I have tried to wipe. The quickest way I have found to get around it is to remove the HDD and get an external HDD enclosure. Connect it up to another PC and wipe it by reformatting the HDD. There may be a ‘System drive’ on the HDD that will also need wiping and deleting so that there is only one partition on the drive. Reinsert the HDD and start again with a completely fresh OSS install. I must admit that I have experienced one or two difficulties when the HDD is reinstalled and the laptop/PC no longer recognises it or runs with it but mostly this works.
Punteggio 0
Hi I was having exactly the same issue. I found a solution with the windows media creation tool. Have an USB ready create the bootable usb with the windows media creation tool, restart and press ESC when the asus logo is loading and then select the USB drive to start up. After the windows installation (Clean or repair) you will need the nvidia drivers and everything else shoudl be working. Hope it helps.
Punteggio 0
Aggiungi la tua risposta
George k sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,301
