Salta al contenuto principale
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542 Domande Visualizza tutte
Turn Off Windows 10 Password Change
It is a DIY PC powered by Windows 10. The computer asks me to change the password from time to time (around one month). The computer has locked for two times because my wife changed the password and forgot to write it down.
Is there any way to turn it off? And any alternative to Ophcrack as it takes hours to find the lost password.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Soluzione Prescelta
Ophcrack is not a great option for Windows 10 password recovery,it takes a long time to run on a computer,i guess it depends on your password.If the password is complex, it will take 10 hours or more to load (I tested it). This only worked for 15 minutes on my computer and solved the problem.
https://www.windows10passwordreset.com/
Punteggio 0
Risposta Più Utile
If it’s signed into a microsoft account use a local account instead without a password.
Punteggio 2
2 Commenti:
It is a local account only.
da
Should be able to remove password when using the change password option instead leave new password blank and it should let you change it to no password.
da
Hi @mowsdeny ,
follow this guide to remove password expiration.
Punteggio 0
Aggiungi la tua risposta
Moris Vankle sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 59
