Salta al contenuto principale
Repair guides and support for wireless and corded computer mice by Logitech.
275 Domande Visualizza tutte
How to take apart my Logitech Mouse #402641
I’m not sure which Logitech mouse I have. I’ve included some pictures and the only number I see is 402641-000.
I’m trying to take it apart and can only find one screw. I have checked under all the pads and there is
only one screw under one pad. There are no other stickers/pads anywhere, not even a battery sticker.
When I take the one screw out, that side comes up some when I pull, but the other side does not. I don’t know if I’m missing a screw somewhere or it is snapped together really good.
Questa è una buona domanda?
Punteggio 0
2 Commenti
r u sure you checked under all pads / feet
da
I'm sure. I pulled them all up and there was only one screw under one of them.
da
Aggiungi un commento
3 Risposte
Risposta Più Utile
It’s a Logitech MX620 based on the part number. The mouse is held together with screws under the pad; you didn’t look hard enough.
If you need an idea on how to take it apart, refer to this video. It isn’t English, but it goes over mouse disassembly and should be easy to follow along.
Punteggio 2
This Logictech is not exactly the same but will probably help a lot:
https://www.youtube.com/watch?v=VThb7EGP...
Without a model number you could look for hours.
Punteggio 1
yes unscrew all of the visible screws and it should come off and then do what you have to do and put back together.
Punteggio 0
Aggiungi la tua risposta
Audrey Hodge sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 730
