Salta al contenuto principale
Annunciato il 16 ottobre 2014, identificabile dal numero di modello A1347 e EMC 2840.
197 Domande Visualizza tutte
Help identifying two SMD components on 2014 Mac Mini A1347 EMC 2840
Hi all,
I’ve gotten my hands on a 2014 mac mini board number 820-5509A. It doesn’t power on at all and I think I’ve found the reason why. Two components are missing from the board. I would like to buy them and solder on the board. Problem is I can’t find schematics anywhere for the mac mini! I’ve attached a photo to indicate the components I need to identify. Appreciate the help! Thanks.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Soluzione Prescelta
The upper capacitor (marked with a curved arrow) is a 1uF/25V (ceramic, 10%, 0402), and the other one is 2.2uF/16V (ceramic, 10%, 0402).
Punteggio 0
2 Commenti:
Thank you so much Lucas! I've taken one 1uF/25V (ceramic, 10%, 0402) from a donor board.... and I've got my hands on a 2.2uF/16V (ceramic, 10%, 0603) as well.... slightly larger case size but I've plenty of space so will solder those two on and report back! Thanks again.
da
We have lift off :-)
da
Risposta Più Utile
charles, there are no schematics for the Mac Mini available anywhere. you will need to take some measurements from either a donor board or have somebody somewhere check theirs for you.
Punteggio 2
2 Commenti:
Thanks, I'm guessing they are capacitors of some sort as they are brown... not black which would typically indicate a resistor. If anyone has a board they can measure up and tell me what it is would be very appreciated. Thanks!
da
@vogelek23 I noticed you answered a similar query. Can you help at all? Thanks.
da
Aggiungi la tua risposta
Charles sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 6
Tutti i Tempi: 267
