Salta al contenuto principale
The Sony Xperia XZ1 Compact is a compact flagship Android smartphone from Sony released in October 2017.
11 Domande Visualizza tutte
Is it ok to glue the xz1 compact top lid?
The thin metal piece at the top of the phone detached from the phone after a fall. Everything still works fine, but still, i’d rather have it attached. Is it ok to glue it, and if so, what type of glue should i use ?
Thank you !
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
@anoyo anytime you need to glue something back, you want to make sure you are using an adhesive that will allow for future disassembly if so desired. I prefer to use epoxy adhesives like Gorilla Epoxy etc., personal preference for sure. If you do not to take it ever again apart remember that you require heat to do so :-)
Punteggio 1
2 Commenti:
Well, for me the lower lid deattached. What can I use to attach it back in, the phone works just fine. Anyways, what can i use and where do i buy expescially for the Sony Xperia G8441??
da
@Luccafo I'd be using E6000
da
Aggiungi la tua risposta
Anna Onymous sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 289
