Salta al contenuto principale
Repair guides and support for motorcycles manufactured by Honda.
speedometer and tach lights not working.
i have a 96 honda gl1500 se. the dash lights work but the speedometer and tach lights do not. any thoughts?
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
3 Risposte
Risposta Più Utile
  • Speedometers are unique in that some of them use physical cables instead of sensors, so a speedometer not working can also indicate a broken cable or stripped gear.
  • If one or more warning lights fail to illuminate when you first turn the key on, it usually indicates a blown bulb.
  • If none of the lights come on at all, check the fuses and wiring to the instrument cluster first.
  • If a warning light comes on and stays on when the engine is running, that usually indicates a problem with that specific system.
Punteggio 3
2 Commenti:
I am sorry I wasn't clear on the request. What I meant was everything is working properly except the lights on the speedometer and tach. Makes it very difficult to drive at night.
da
da
Speedometer light Horan not working
Punteggio 1
I have a splandarbike but many problam this bike Bhai is smoking and the noise is very directly and not speed
Punteggio 0
Aggiungi la tua risposta
ken_choat sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 3,619
