Salta al contenuto principale
Model A1347. Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
Getting S.M.A.R.T. errors on Apple SSD disk.
Hi,
I have this problem: My Fusion Drive in my Mac Mini Late 2012 is failing. I have S.M.A.R.T. errors on the Apple SSD drive.
So I have decided to upgrade to an 1TB SSD Samsung 860 QVO. But, I have many errors. I can't restore from TimeMachine and I can't reinstall from internet. On reboot I have crash.
So can you give any help? It seems that my Mac Mini is searching for 2HD (Fusion) and not only one... so gives me errors. Is there a solution?
Bye
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Risposta Più Utile
First you need to put your system back to its original config with the HDD and the SSD installed. Then you will need to break the Fusion Drive set so you can take the drive out. Follow this guide Split Your Fusion Drive Apart
Once you’ve done that you can then reconfigure your drives.
Are you sure you’ve identified the correct drive? This system has two 2.5” drives which look the same! So make sure you’ve ID’ed the correct drive.
Sostituzione disco rigido Mac mini versione fine 2012 A common issue is the ribbon cables fail so you may not have a bad drive but a bad cable. That can explain your OS install errors.
Punteggio 1
1 Commento:
Thank you. I have Mojave on my macmini so your guide is not for me in all steps.
In Terminal i have to digit different commans to split my Fusion… but in general this answer solves the problem.
Bye
da
Aggiungi la tua risposta
fabio sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 328
