Salta al contenuto principale
Il telefono allora al top della gamma Samsung, il Galaxy S8, è stato lanciato nell'aprile 2017.
304 Domande Visualizza tutte
Battery drainage due to motherboard issue
My samsung galaxy s8 battery drains very fast,even in idle mode.
Customer care service says,its an issue of motherboard,battery replace will not solve this.
How can i fix or refresh motherboard without repairing it?
NB: phone overheats during charging.
Thanks in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
2 Risposte
Risposta Più Utile
@jnemon I am not sure who your Customer care service but you do want to start with a new battery first. You cannot proper troubleshoot without doing that. If that does not change anything you will have to troubleshoot the charging circuit. So start with a known-good point like a new battery
Punteggio 1
Hi @jnemon
PMIC is a common failure for the Samsung S8 series. The typical failure will eventually result in the phone being completely drained and unable to turn on at all (its a good time for you to check the back-up settings).
Here is the replacement process for this chip: https://vimeo.com/274029552
If you aren’t comfortable with this repair, you can get the logic board replaced through any Samsung Authorized Service Provider. If your phone is still under warranty, there would be no cost associated with the replacement.
Punteggio 0
Aggiungi la tua risposta
Life is BEAUTIFUL sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 15
Tutti i Tempi: 1,643
