Salta al contenuto principale
Lanciato nell'aprile 2016., identificato dal numero modello EML-L29.
[P20 Lite] Is the problem with my screen or motherboard?
I was given a phone what had fell down from a high place, if you turn the phone on / or put the charging cable in the phone, the phone vibrates, a flashing red-light occurs at the top of the phone and screen gets some red&blue&green lines running through it.
I’d like to know if the problem is with the screen or the motherboard, is it worth fixing?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Hi @roal ,
it’s a LCD&Digitizer issue. Follow this video to see, how to repair your issue.
Punteggio 1
2 Commenti:
Thanks, just put my order in for new LCD & frame.
Cheers mate, hopefully I'll be able to make the repair :)
da
You are welcome, you will fix it! :) Good luck
da
Aggiungi la tua risposta
Raul sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,703
