Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
678 Domande Visualizza tutte
I have replaced the defective home button with new
As I replace the lcd screen of my iphone 8 plus
I accidentally damaged the ribbon cable cutting it off
So I replace the home buttin with new but it
does not do the function at all. Checked the connection and it is ok. What could be wrong?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Aftermarket home buttons typically do not function on the iPhone 7/7+/8/8+. If you use JC or HX home buttons you should be able to regain home button functionality, but Touch ID will be unavailable.
Hope this helps!
Punteggio 0
4 Commenti:
So where can I buy these JC or HX home buttons? Can anyone tell me please.
da
You mean the original replacement home buttons right?
Aftermarket ones like you've mentioned will work.
da
@benjamen50 They will lose the touch ID with a third party button, right?
da
That is correct, they will retain basic home functionality but with touch ID function lost.
da
Aggiungi la tua risposta
Eiji Uehara sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 66
