Salta al contenuto principale
Google's third-generation Pixel-branded smartphone, and their first "notched" phone. Comes with a 6.3" QHD+ OLED display and 64 or 128 GB of storage. Available in Nearly White, Just Black, or Not Pink.
My phone doesn't work
So I sat on my google pixel 3 xl. When I did so I heard a crack sound like a screen broke. I got up and looked at my phone and it will not turn on, vibrate, or make any sounds to let me know if it still works. Before I sat on it had a cracked screen in the very bottom corner, not even where the OLED screen is, it’s right next to the speaker. Everything still worked just fine before this. Google wants me to fix the screen then they will try to fix the problem. I just want to know if you guys think you know what could have caused the problem, so I can fix it myself or something.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Hi Cooliphonexbox,
the damage is depending on the force of the pressure. You must disassemble your mobile phone and check what’s damaged and what could be the best solution to fix. It may be damaged motherboard of phone or just issue with the connection between the screen and the PCBA. If you don’t have experiences with measuring PCBA or functional test, give the mobile phone to the repair center, in the other way, follow quick guide
Punteggio 0
Aggiungi la tua risposta
Cooliphonexbox sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 17
Tutti i Tempi: 202
