Salta al contenuto principale
Modello A1419 / EMC 3070 / Metà 2017 / processori Core i5 3.4, 3.5 o 3.8 GHz o Core i7 Kaby Lake 4.2 GHz (id ImAC18,3) / Retina 5k display. Fai riferimento alle guide del modello più vecchio dell'iMac 27" Retina 5K display (fine 2014 & 2015), dato che il sistema è molto simile.
293 Domande Visualizza tutte
Can I replace the HDD with an SSD?
Can I replace my factory HDD with a Samsung 860 QVO SSD 2TB, (I do have the bracket and termal sensor cable) or is there a faster/better drive at a descent prize?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
There are four models in the 2017 27” machine, which one do you have?
Standard Storage:1 TB (Fusion)Std. Storage Speed:N/A
Details:This model has a 1 TB "Fusion" Drive, which combines a 32 GB SSD and a 1 TB hard drive. It has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive and a PCIe connector for the SSD.
At the time of purchase, Apple also offered a 2 TB "Fusion" Drive for an extra US$200 (128 GB SSD and 2 TB hard drive) or a 256 GB, 512 GB, or 1 TB SSD for an extra US$100, US$300, and US$700, respectively.
Punteggio 2
1 Commento:
I have the standard storage 1TB (Fusion)
https://everymac.com/systems/apple/imac/...
da
Aggiungi la tua risposta
Anders Berglund sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 46
