Salta al contenuto principale
The ZTE ZMax Pro is identified by its black color, rear fingerprint sensor and its model name, Z981, which can be found under the rear case.
20 Domande Visualizza tutte
replaced the battery display wont go on
ive replaced my battery,the phone will charge and is on but the diplay is black, i can hear text messages come through and emails and such but cannot get the display to be on pleas help
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Check the LCD connection to the main logic board, it is possible that there might be dust or an off connection causing your problem.
Looking through the teardown, I can’t help but notice the long LCD cable running right underneath the battery. It is very possible that this might be damaged from the battery replacement. Good news is, trying a replacement screen isn’t that expensive.
Punteggio 1
Aggiungi la tua risposta
gregberserker13 sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 55
