Salta al contenuto principale
Modello A 1990 / EMC 3359. Lanciato nel maggio 2019 con nuove opzioni di processori esa-core e octa-core.
My screen has a purple scar and screen is always black
My screen has a purple scar and screen is always black, anyone knows how to solve, if it need reparation or substitution of the screen?? Maybe can be covered by warranty?
Questa è una buona domanda?
Punteggio 1
3 Commenti
Is that not a crack on the bottom left??
da
It seems not to be a crack, at least not in the front screen. Inside maybe
da
Your display is made up of two plates of glass the back one is cracked which is why your screen is discolored. It looks like something was on the keyboard and the lid was closed pushing up as you closed the lid the black circle is the pressure point of the object.
da
Aggiungi un commento
2 Risposte
Soluzione Prescelta
@cento2 sorry, but that is a crack. Your outer glass is not cracked but the LCD screen is. The only way to fix it is be replacing the display.
Sostituzione Schermo MacBook Pro 15" Touch Bar 2019
Punteggio 4
Connect an external monitor or a TV to it. you will then know if it is a crack or not
if not it will show up on the external monitor
Punteggio 2
Aggiungi la tua risposta
Vicent Avaria Avaria sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 860
