Bottom screen peeling/loosen up.
Short story, the bottom is kinda loosen up a bit, should I apply an adhensive of some kind to fix this?
Questa è una buona domanda?
If you push on it gently does it go back into place? If it feels like something hard is keeping it from sealing, then you will need to open it further to take out whatever piece is getting in the way.
If its simply bad adhesive, you have use a strip of double sided adhesive/tape in that space to seal it back up. I would not recommend any type of glue as it could get on your LCD screen and be impossible to remove.
I'll try a double sided adhesive tape, once I got the chance to buy a quality one, any recommendations on this?
Tried pushing it back gently, it does stick for a few seconds until it return to this state.
Any double sided mounting tape will work. I recommend the "red tape" available for phone repair. It has a good amount of hold for the price.
Ultime 24 Ore: 3
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,284
