Why is the water tube to the ice maker freezing
The water tube keeps freezing over and then popping out in the back of the ice maker. We have cleared the tube several times. Once it clears it makes ice for about two days and then freezes again. What can we do to keep it from freezing. The ice maker works well other than this issue.
Questa è una buona domanda?
Try rerouting your line from the valve to the ice maker assembly. Where it’s goes in the freezer doesn’t make it loop high try keeping the loop short as possible. What’s happening is the water is dripping and freezing when the valve is closed. With a short loop there’s less water
da Franklin Wilson
