Salta al contenuto principale
Model No. A1367 / 8, 16, 32, or 64 GB capacity
915 Domande Visualizza tutte
Domanda Chiusa
Why is the front camera image blurry after screen replacement?
I replaced the broken front screen and front facing camera and now the images the camera takes are fuzzy/blurry. I checked the lens area for adhesive, and found it was clean. Did I miss something?
Questa è una buona domanda?
Punteggio 0
1 Commento:
As it turns out, the replacement camera was to blame for the poor image. I replaced it with another new one and the image is normal. It looks like it was a defective part. Thanks!
da
Aggiungi un commento
2 Risposte
It could be loose or there are fingerprints on the lens
Take it apart and wipe the camera down with a soft cloth till there is nothing on it(clean)
If there still is, the camera my be bad so you may have to have the display assembly exchanged
Punteggio 0
when you put on the adhesive 3m tape to connect the glass down is it going over the spot where the camera is? I have ordered pieces of tape that werent perfect and they went over the camera area which would make it blurry, you would need to cut that portion out.
Punteggio 0
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 2
Tutti i Tempi: 24,479
