Salta al contenuto principale
Repair guides and support for the Nikon D800 and D800E digital SLR cameras announced in February 2012.
19 Domande Visualizza tutte
Big front focus (out of the norm)
Hello, Is it possible to correct a front or back focus problem that is out of the ordinary (more than +20 / -20) ?
Bonjour, est il possible de corriger un problème de front ou back focus totalement hors norme (plus des +20 / -20) ?
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Have you set the viewfinder diopter so that focus is sharp at some point?
Are you having the same problem with manual focus lenses?
I know that modern autofocus lenses can be calibrated, you may want to check the proper technique for doing so. YouTube is your friend for this sort of thing.
Punteggio 0
1 Commento:
I'm talking about an autofocus problem, I don't see what the diopter has to do with it.
In manual and with liveview, I don't have a focus problem.
On Nikon D800, it's the general setting that can be changed, but this camera has a problem outside the possible correction level.
da
Aggiungi la tua risposta
MrSoul sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 7
Tutti i Tempi: 164
