Salta al contenuto principale
Lanciato il 22 settembre 2017. Modelli A1864, A1897. Disponibile in versioni GSM o CDMA / 64 o 256 GB / gold, silver e space gray.
678 Domande Visualizza tutte
Is it possible to fix nand and cpu of iPhone 8 plus logic board?
this is a continuation to my previous questions. I damaged cpu and nand in iphone 8plus logic board while trying to replace back glass. Can cpu and nand be replaced or fixed, or do i buy a new motherboard? Thank you so much.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione Prescelta
They cannot be replaced, that’s for sure. As for fixing them, it depends on the extent of damage, but even the “simple” reball of the CPU is quite a demanding task. The NAND may also need programming tools and skills. In any case you probably need a reputable and very skillful microsoldering tech and some testing to be able to give a definite answer to your question.
Punteggio 3
2 Commenti:
I went on to put it dfu mode, now either it stays in recovery mode or stays on with apple logo.. nothing more. I dono how to fix it. what to do? is it good to buy a second hand motherboard? can you rely on second hand Logic boards
da
@udaymaclean Symptoms point to a board failure, no idea if it could be fixed at all with the little info available. A used replacement board would be a viable alternative since the oldest in the market are just 2 years old, but in general their reliability is directly related to that of the seller, so choose wisely. Good luck with it.
da
Aggiungi la tua risposta
uday maclean sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 5
Tutti i Tempi: 763
